AAKVIPER
I hope the wire in the picture is the famous and correct green wire under the dash.. ?
I will try to use Ron's list..
http://forums.viperclub.org/threads/557774-Key-Fob-Remote-Programming-(DIY)-by-Ron
But gentleman, I need help in the details like whether I got the correct green wire or not?
What part on the car is the best place too ground the green wire on the gen 1 Viper?
Then from Rons' post I turn the ignition to run position while green wire is still grounded!
Then the EEM acknowledges entry into programming mode by flashing the dash LED.
(All GEN I) Press and release the arm or disarm button on either FOB, then same for the next key.
Thanks for any advice, Arthur
