give me a break...
Luke@tirerack
more exactly a Spring Breakl ... can you believe it, it's already spring. Time for cruising, AutoX and track days :headbang:.
Since we are talking about brakes here's a couple of good deals on ... well, brakes for your SRT10
PowerSlot direct replacement slotted rotors
$464.00 per set plus shipping
It’s a fact that venting the gas emitted by hot brake pads improves overall brake performance and helps minimize fade. At one time the conventional wisdom in racing circles was to cross-drill brake rotors to aid cooling and eliminate the gas emitted by brake pads. However, today’s elite teams in open wheel, Indy and Trans Am racing are moving away from crack-prone, cross-drilled brake rotors in favor of rotors modified with a fatigue-resistant slotting process. Power Slot rotors bring this technology to the street and are specifically designed to run cooler, promote dramatically improved wet and dry brake performance, and are a safer alternative to drilling crack prone holes through cast iron rotors.
The Power Slot slotting process removes far less of the rotor’s surface area than conventional cross drilling to help maintain the highest possible co-efficient of friction for the brake pads to work against. Slotted rotors trade only 3. 7% of their surface area to the slots that vent the gasses, while drilled rotors sacrifice up to 7. 75% of their surface area, and rotors that are both drilled and slotted sacrifice up to 9. 38% of their surface area. Less surface area means less stopping friction.
Starting with select castings manufactured in Italy and the U. S. , all Power Slot rotors are CNC machined to application specific tolerances that utilize a patent pending tapered-slot technology to create a vent for brake dust and pad gasses while preserving rotor strength.
The slot designs of Power Slot rotors are angled to use the rotors’ direction of rotation to enhance performance. This makes them side specific with left side (driver’s) and right side (passenger’s) rotors.
Brightly-plated Power Slot rotors also eliminate rusty rotor syndrome and enhance the look of custom wheels. Their military spec cadmium plating adds a high-tech appearance and corrosion resistance.
Power Slot rotors are designed to beat the challenges of high performance driving and severe duty brake demands, and represent one of the most cost-efficient performance brake upgrades offered in the market today.
______________________________________________________________________________________________________________
Disc Brake Australia
5000 series
4000 Series
DBA 2-piece 5000 series fronts and 1-piece 4000 series rear
$1196.00 per set plus shipping
With a two-piece design and a black Alumalite™ centre hat, DBA's 5000 series slotted rotors complement the looks of a great looking performance car. As with every DBA rotor, the 5000 Series 2-Piece rotor bolts right onto the vehicle with no mechanical changes needed.
The 4000 Series Wiper-Slot rotor has a unique 6x6 slotted design for extreme stopping power on the road and the track. As with every DBA rotor, the 4000 Series rotor bolts right onto the vehicle with no mechanical changes needed.
DBA's mid-series, enhanced-performance, slotted rotor features Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
All 5000 Series rotors and many 4000 Series Rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
TSP is a propriety process specifically developed by DBA for improving the performance of disc brake rotors. Benefits of TSP include:
  • Improved fatigue resistance to minimize surface cracking
  • Reduced rotor fatigue during prolonged heavy braking
  • Quick replacement, minimal ''bedding-in'' of rotors
Thermo-Graphic markings are placed on the outer edge of each DBA 5000 series disc rotors and are used to monitor the core temperatures achieved during braking application. The markings change color as the rotor heats up to alert the driver to rotor temperatures that exceed optimum levels.
''Kangaroo Paw'' is a patented, high-tech disc rotor ventilation system designed and manufactured in Australia by Disc Brakes Australia and available on rotors for select applications. "Kangaroo Paw" technology delivers significantly improved braking performance. Even under extreme braking conditions. Kangaroo Paw rotor designs run cooler, are stronger, and outperform traditional straight-vane disc rotors.
The ''Kangaroo Paw'' design features a series of 144 diamond- and tear drop-shaped pillars and columns individually spaced between the rotor faces.
This system provides two key advantages.
First, is the ability to cool the rotor faster than ever before. As the disc rotor rotates, aerodynamic turbulence around the individual pillars and columns is generated, increasing the force of hot air out from within the internal areas of the rotor.
Second is increased dimensional stability across the disc rotor directly achieved by the individually spaced pillars and columns.
These advantages increase the disc rotor's efficiency by as much as 20% when compared to conventional rotor designs. A 20% increase in disc rotor efficiency directly translates to reduced brake operating temperatures, brake fade, disc rotor stresses, disc thickness variation, run-out and shudder.
All 5000 series rotors also benefit from DBA's "Longlife Slotted" design. The rotors are manufactured to QS-9000 quality standards using premium grade materials with a high iron content and dense metal matrix resulting in long wear and safe, consistent stopping power.
  • Unidirectional slotting (left and right) increases pad bite, reduces fade and delivers exceptional braking performance.
  • Slots continually de-glaze the brake pads improving efficiency and reducing rotor scoring.
  • Slots even out-wear across the brake pad faces, increasing the effective contact area and extending rotor life.
  • Slots help dissipate water when driving in poor weather, as well as pump away dust and dirt.
  • Slotting also combats "out-gassing," where gas (from the pad bonding agents) can form a cushion between pad and rotor, greatly reducing braking power.
DBA rotors are chosen as Original Equipment on many vehicles.
you can call me directly or use this link to place your order
http://www.tirerack.com/a.jsp?a=BO1&url=/brakes/index.jsp
BarryLB
