AAKVIPER
example, kumho or nitto in the fronts and Michelin Pilot Sport 2 at the rear.
Arthur
Arthur
Arthur
TowDog.
Reason is that you have upsized your front tires, but not the rears. The fronts will stick better with the larger tires, but the rears grip will be the same as stock.
Most modern cars are designed with some understeer in the front to keep the rears from sliding out in normal driving.
This can even happen with putting fresh tires on one end, and leaving older, harder tires on the other end.
That is why it is not usually recommended to put different construction/brand tires on the same car.
For firmly sprung vehicles like the Viper, you can get some nasty handling surprises when nibbling at the edge of adhesion.
TowDog.
And what if in that exact moment that driver makes that one in a million chance move in front of you, that an asteroid lands in the middle of your hood?
What he said
obviously you didnt read another thread from canada dry guyGuess that's why you keep chiming in?
