Header size question
rt/10stew
Cambridge,Ontario
Hi I am looking at buying some headers the seller tells me that the I.D is 1 5/8" and the O.D. is 1 3/4". So my question is what size are these ? as I do not know if headers are sized by the O.D. or I.D.
Thanks Stew
RTTTTed
My experience has been that the size measured is the ID. 1 5/8" is not 1 3/4" OD a the tubing is smaller than 1/16. This is not always true and there are differences between steel and SS, etc.
Superhcharged engines (like mine) need 1 3/4" headers and if they are the Belangers 5>2>1 the pickles must be removed for the headers to make power.
Normally aspirated can use 1 5/8" OR 1 3/4" headers. Highly modified n/a engines also need the 1 3/4" headers for a slightly better performance (gas mileage and/or hp).
1 5/8" headers are best for stock. 'Tuned' (read expensive) headers are the best for all applications, but the difference in hp is often not worthy of the much higher cost.
Ted
R
rt/10stew
Cambridge,Ontario
Thanks for the reply Ted. But I am still unsure of how these are measured. I am looking for 1 3/4" as I am planning on adding a supercharger. So are 1 3/4" headers an O.D or I.D measurement ?
T.I.A. Stew
RTTTTed
OD measures 1.735" so if you want to get technical, they aren't 1 3/4" on the outside either, but I'd guess that the bends make the tubing larger and smaller and the measurement is different in different places so it is kind of irrelevant anyway. .015" isn't worth mentioning either so I guess we could say the 1 3/4" must be the outside measure.
I'd recommend just don't buy cheapo. Stick with brand names.
Ted
R
rt/10stew
Cambridge,Ontario
Ted
Thanks Ted that is what I wanted to know
Stew
SKY1960
