AtRo Racing Products Heat Elimination Kit AtRo Racing Products Heat Elimination Kit consists of a wrap that you put around all of your exhaust system including the cats, mufflers, pipes, and crossover. After attaching this wrap with the supplied stainless steel clamps you will coat the entire system with the supplied coating which seals all the pores and makes the wrap waterproof. Also supplied are custom cut mating that goes inside of your car between your carpet and the side sills. This mating runs along the hole side of the sill from the back of the seat to the front of the footwells and forms a barrier to keep the heat out and the A/C cool air in the cabin. We also supply custom cut mating that goes under your floor matts and is glued to the bottom of the mats. Then you will glue the supplied rubber mating to the bottom of the heat shield on the mats. This is an easy to install kit that does not alter the looks of your car in any way.
Robbie
Feel free to call me at 203-641-8569
