BurnR8
two things I can think of.....one is a guess....1) I am guessing you would need to start the car a few time to let the ECU cycle on the Trouble code....take it for a drive and let it run its test....2) unhook the battery and clear the ECU this will start everything all over but you will lose what your puter has learned to date....which is ok cuz it will learn it again over time.....all that being said....if the new gas cap does not seal correctly your puter will keep giving you the code....sorry about the vandalism....makes you scratch your head....
