HELP!!! Having Extreme Difficulty with SIDE CURTAINS ...(Removing & Replacing)
Jeff Torrey
Plaistow, NH USA
The more you do it the easier it gets. When you get frustrated with anything on the car it's best to take a break.
If the door is out of alignment you will have to take it in and have it serviced.
Open the door all the way. Put the slots in the tracks. Now lean on both the front and rear (top). Smack the window frame with the palm heal of your hand down at the base, near the hinge of the door. Forcing the window to the rear and it should hook up. Keep in mind that the fabric needs to seat on the door frame, so that means that the window has to be inserted quite a ways to catch the pins.
Hope this helps.
Sorry about your current problems...when you get things back to "normal"...you might consider looking into the Vipermania windows...they are a breeze to install...NO silly thumb screws...AND they are an excellent fit.
Vip-RT10
Clearwater,FL.USA
I had the same problems with mine. It took a while to understand the way it went in and what i did. The solution was to backup what you did, or the inverse. The guide rails are long and have sharp angles,they may have jammed in the spaces between the housing. Once I removed the windows, I bought the V-mania windows and roof, they are excellent. Good luck.
