Yank all of the screws. The tree fastener you can pop loose by pulling the panel away along the back edge opposite the hinge end. Be careful along the top and near the stanchion.
Once the tree fastener is loose lift the panel off the window frame still watching the stanchion as it kinda likes to lock in there.
Once the panel is free do not go anywhere with it. There are 2 wiring connectors above the speaker area to undo. Then you are done.
NOTE: many folks THINK the regulator is bad, when its only the shuttle-clip from the regulator to the track that broke. If the CLIP is broken, Chrysler makes you buy an entire expensive regulator.
