jmillsUT28
I installed the Zeitronix datalogger system in my car last week. Have not had much time to play with it but did make one 3rd gear pull to log. I hear that it is best to have the AFR in between 11.5-12.0. Now is this when you are at full throttle/boost? This is what my logger system showed at the highest TPS/RPM/Boost.
AFR: 10.8
RPM: 5908
Boost: 6psi
TPS: 82
Now I have my boost sensor tapped into where my Split second box taps. Which is where the stock MAP sensor is. It is showing 6psi but when I went to the dyno before I installed all of this they said I was at 9psi. Should I have this sensor tapped somewhere else?
AFR: 10.8
RPM: 5908
Boost: 6psi
TPS: 82
