so lately i've had nothing but issues with my build. I decided to install the Roe power steering bracket onto the head today. Put the supplied spacer between the head and bracket and started to torque to 28 ft/lbs which the supplied instruction says. The top two bolts kept turning and turning and turning, took them out and the thread from inside the head came out with the screw. At this point what are my options? There's still about an inch of thread left inside the head and the bottom bolt is fine. Should I get a longer bolt and torque to spec?
Edit: Images added and I also went back and checked the torque settings on the torque wrench, it is set to 26 ft/lbs...so I couldn't have over torqued the bolt...
