whitebluevipe
I have a Gen 1 that no longer blows cold air. how hard is it to recharge an AC system and what exactly is involved? I have never done this before but was hoping I could do it myself. any imput will be appreciated.
"R-136a" is interesting.
Our 95 and 96 Gen I's use R-134a.
As Tom said, it may take 3 cans (small)...I usually buy the kit for about $30-40...contains a couple of cans and a guage...note that there is dye for leak detection in many.. READ the cans carefully!!
I don't think that is a problem...but I think that you are supposed to let the tech know about the dye (not that you can't SEE IT around the low pressure port !!!) BEFORE he does a recovery of your refrigerant at a later time.
Seems that some of the cannisters have a different level of compressor oil mix as well...at least by my memory.
Have gotten my R-134a at Advanced Auto...called "Arctic Freeze" and "Big Chill"...ALL made by "id" which is "interdynamics".
The guage/hose/ connector will ONLY fit the low pressure side,
Follow the directions on the can and you should be fine (as long as the guage is OK...these cheap, disposable things ane not meant to last for too many uses).
As a back-up, I do cross-check pressures with a Snap-On set fot R-134a systems if things "don't seem right".
