Help! Starter button's won’t starting it.
Andrew/USPWR
W. Palm Beach
Help! Starter button\'s won’t starting it.
I was burning off the last of my rear tires, popped the clutch and it killed the engine. Went to fire it back up and nothing. Lights all working but the starter button isn’t doing a thing. Got a hold of John B. and he thought it might be the switch attached to the clutch pedal. Any thoughts or ideas would be greatly appreciated.
Andrew
Cape Coral, FL
Re: Help! Starter button\'s won’t starting it.
Ditto on the clutch pedal interlock switch...
Tom Sessions
Hampstead,NC.
Andrew sorry I missed your call.Check all the fuses in the fuse box under the hood.I have seen one of them blow and cause a no start.I'll try and call you on saturday and see what you found.In the mean time you should be able to push start the car if you need to get it running.
Tom
Andrew/USPWR
Andrew/USPWR
W. Palm Beach
Tom
Thanks Tom, sorry for the late call. I did try push starting it a few times with no luck. I figured the fuel shut off with the the push starter. I'll be wrenching on it in the morning and give you a call.
Thanks again
Andrew/USPWR
Andrew/USPWR
W. Palm Beach
And sorry to all about the grammer in the subject.
When you leave your home in a Dodge Viper and come home in a tow truck, it screws with you:-(
ccronald
Western New York
I had the same problem. Push starting didn't work. Turned out to be a 20 amp fuse under the hood. I now carry a spare fuse in the glove compartment!
Andrew/USPWR
Andrew/USPWR
W. Palm Beach
A fuse would be great. I have the car at my shop and I'll check the fuses when I get there.
thanks all
Andrew/USPWR
Andrew/USPWR
W. Palm Beach
It was a 25 cent Fuse.
20 amp ASD fuse. What ever that means.
I happy and the snake is ALIVE:)
Shandon
Northern Kentucky
Damn.. you know your having fun when you can can melt the tires and a fuse at the same time.. Sweet!! :) Glad to hear it worked out with a simple fix!!
zorroespanol
VCA Member - New England
Miami Beach, Fla. U.S.A.
Andrew
05 and melting off the tires?? somebody is not wasting his time letting his viper sit around...
Andrew/USPWR
Andrew/USPWR
W. Palm Beach
Andrew
I only have a short drive to work every day so I try an make the most of it. I guess I've been making too much og it. 8K on the Odometer.
Warfang
California, East Bay
I've never been a fan of the start button... that's one more piece of electronic that can go wrong, and in this case, did. It's just reinventing the wheel. There was nothing wrong with a mechanical, key-turned starter. If anything, it's less confusing.
SimpleJack
