DEVILDOG
VCA Member North TX
Re: HELP - Those who have adjusted stock Koni\'s!!!
Jeff, I explained previously that I did not dyno mine because I did not have the time during the install of my Eibachs to go take them somewhere to do it. The decimal dust cost is not an issue. Also, as far as I'm concerned, Koni's production process should have them equal anyway and they indicate that they dyno all their shocks as a quality control to assure consistency. As stated by another, I doubt seriously that Koni shipped shocks to DC in sets of 4 with each one dyno adjusted to an equal setting for application to one Viper. Do you think that Koni or any other shock manufacturer takes their non-adjustable shocks and dynos each one and ships balanced sets of 4 to each car company for installation to each individual vehicle? I also doubt that DC took 4 separate shocks out of the parts bin and dynoed each one and adjusted them prior to installation on each Viper. Therefor, assuming consistency during production of the shocks I set mine exactly the same for the fronts and exactly the same for the rears(firmer in front than rear). My point in posting is only to relate to others some detail of what I discovered on my car and what I did to help them should they undertake this mod as both you and Tom did. I'm not trying to say what I did is any better or worse than what you or Tom did. Hopefully, the next owner that does this can read all the information we have all provided and make an educated decision on what they want to do and have an easier time doing it.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
"First of all, each of my OEM Konis were set different from the factory. Won't detail each one, however, I'm pissed they were not the same and am glad I set them myself today "
They were set different so they would be equal, setting them the same will make them uneven. I don't know why no one will spend the 25 bucks a shock to dyno to have a better ride. And to give you an example, I had to set one at 3/4 turn and the other just over 1-1/8 turn to have them equal. The adjustments get progressively bigger as you turn in. It wasn't much to have them dynoed ($100 for all 4)
