Help with gas pedal
agentf1
Phila Suburbs
My gas pedal fell off today. I was able to figure out how it goes back on and hook up the spring but I think the pin may need to be pressed in more so it does not come apart again. Is that pin a pressed fit into the bar it hooks onto? If so how do you get it pressed in further so it does not work itself loose again. Right now the end is flush with the side of the pedal and I think it should come through another 3/8". :confused:
sdaddy
Jacksonville, FL
This can be an all new excuse of losing a race. Instead of "I missed 3rd gear" Viper owners can now use "my gas pedal fell off".
Andrew/USPWR
W. Palm Beach
It happened to my GTS. It was a few years back and I think I bought a new peddle and simple pressed the cap back on with a large pair of pliers. But I did drive it for a few days with just the brace.:D
As I recall, the L that holds the peddle seemed to lean down away from the brake peddle and therefore putting extra pressure on the end cap. It never came off again after that.
Good luck.
