agentf1
My gas pedal fell off today. I was able to figure out how it goes back on and hook up the spring but I think the pin may need to be pressed in more so it does not come apart again. Is that pin a pressed fit into the bar it hooks onto? If so how do you get it pressed in further so it does not work itself loose again. Right now the end is flush with the side of the pedal and I think it should come through another 3/8".
