help with oil cooler lines
96fl
Hello
I am seeking an oil cooler line for a 1996 GTS
there are 2 of course, the one with the larger 90 degree turn part#4848310 i recieved from Tators Garage (Chuck is extremly helpful)
What i can't locate is the line with the tight 90 degree turn part #4848300 is unavailable
Is there any one out there with one available or knows where to get one
I have checked with Parts Rack and a fellow named Paul Sharf i think out of wisconsin
I am in a bind and need to move my viper in the next week
please help if you can Bill
Take your old line to Earl's or similar shop...and have new one made. I have done this for a friend in a similar situation...worked well.
Good luck!!
96fl
had a set made by a hydraulic shop here in jacksonville
they had a very difficult time finding the fittings
what they did come up with was 1 1/16 hex wich wouldn't fit thru the opening
after i put them on a surface grinder and turned it into a 1 hex i was able to see that the 90 degree bend was two large
thanks for your reply i will have to try another place
VIPER BAZ UK
ENGLAND
They were hard to get and expensive a few years ago when i tried. Even Chuck T stuggled as they were on back order from DC..... Got a set made up from a company called Pirtek here in the UK....
MTGTS
Orlando, Fl
There was a set on ebay a week ago, also try calling Paul Sharf
96fl
thanks for the replies
paul sharf told me that most of the vipers he dismantles
are front end wrecks and that these hoses don't survive
also that he sells every set he gets
MTGTS
Orlando, Fl
96fl
thanks for the links and your efforts
i will recontact him tomorrow
Johndirt
