TOPDOG RACING
- Joined
- Sep 10, 2007
- Posts
- 13
- Reaction score
- 0
Im Looking For Help With My 1995 Rt/10 Venom 600.
I Know Its A Hennessey & I'm Familiar With His Lack Of Honesty. However I Bought The Car From Some Old Gizilionaire In Nj Who Gave Up On The Car After He Bought It New As A Venom 600 & Paid Like $100k For This Thing. When I Got The Car It Had 4600 Miles On It And Was Completely Screwed Up. Apparently The Owner When He Got It From Hennessey Didnt Like Driving It Because He Said It Was To Hard To Drive & To0 Fast So He Had Someone Try To Detune It By Taking Off The Hennessey Parts Like The Headers, Exhaust, High Flow Air Cleaner & Put Back The Stock Throttle Bodies. Needless To Say It Ran Worse, So He Parked It In His Mega Garage And Forgot About It.
Since I Had It I Have Been Unscrewing This Car By Bringing It Back To Alledged Venom Spec. I Installed Belanger Headers & Side Exhaust Kit (no Cats), Side By Side Cone Style K&n Air Filters Also From Belanger, Low Temp Thermostat, Wires, Plugs, New Motor & Trans Mounts & Roes Fan Kit.
The Car Seemed To Run Ok For A Couple Of Hundred Miles But Always Had A Stumble On Take Off No Matter How Many Time I Adj The Trottle Cables. It Also Boggs At A Low Rpm Cruise To The Point That It Seems To Be Starving For Fuel But If You Downshift And Give It Gas It Will Take Off . When You Go Into A Low Rpm Cruise Again It Will Do The Same Thing So I Changed The Trottle Position Sensor Now I Cant Even Make It Down The Street, The Car Bucks, Pops, And Completely Boggs Unless You Go About Half Peddle Then She Will Take Off But Still Running Like Crap.
I Checked To Make Sure The Sensor Was In Right (its Not Rocket Science), And Even Put Back The Original Sensor And The Same Thing. The Car Starts Fine But Is & Always Did Run Real Rich, I Always Thought It Ran Rich Because Of The Cam, Which You Can Definitly Hear The Choppy Idle. Also I Know Hennessey Installed The Aluminum Flywheel & Short Throw Shifter But I Never Pulled The Valve Covers To See If The 1.7 Td Rockers Are There, The Invoice From Hennessey Lists Them In The Pkg But Who Knows.
I Really Had The Car Close To Top Form But I Have No Idea What The Hell Is Up With It Now. Does Anyone Have A Clue ? Respond Or Call Me 862-703-0159 Thanks All
