Hitting rev limiter at 5500 rpm?
gofastr
N. E., Fl.
This is about the third time this has happened in my 08 coupe. While accelerating in second gear, at 5500 rpm, the rev limiter kicks in. I get the CEL light, another flashing red light, and reduced engine power. Any ideas why this is happening at only 5500 rpm?
KNG SNKE
Portsmouth, Rhode Island
Original owner? Flashed PCM?
Garron
There is a well known bulletin to update the engine computer on the 2008.
SUBJECT:
Flash: MIL Illumination with DTC P0300 - Multiple Cylinder Misfire Set. Special Flash
Procedure Must Be Followed
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) and performing the Learn ETC routine with the StarSCAN®.
CAUTION: Be sure to follow the Repair Procedure steps in the order listed. PCM
damage may occur.
MODELS:
2008 (ZB) Viper
NOTE: This bulletin applies to models equipped with a 8.4L engine (Sales Code
EWE) built prior to April 1, 2008 (MDH 0401XX).
SYMPTOM/CONDITION:
Some customers may experience MIL illumination along with a limp in condition with
limited power after the MIL. Further investigation by the technician may find Diagnostic
Trouble Code (DTC) P0300 - Multiple Cylinder Misfire is set.
redtanrt10
Dana Point CA
May need to be flashed like Garron posted, or possibly a bad cam sensor. The trouble code will tell you
webironmongery
