Hood repair question
Ulysses
San Diego, CA. USA
One of the studs that holds the hood louvre down busted off at the surface of the hood. Is there some special epoxy I should use to repair this or will the standard hard drying epoxy for body repair used to fill holes and such work? Or am I SOL?
Thanks,
Ulysses
P.S. If you all ever use the top portion of your car mask, don't pull too ******* that adjusting strap!!!!!
