VEC-1 won't help you much when you remove cats - the rear O2s notice the missing cat and set a "check engine" code. And you definitely don't lose torque with headers & no cats.
That said, why not get a pair of high-flows? You will avoid the fault code and attendant loss of power, you'll avoid the nasty gas smell, and you'll lose -maybe- 1-3 HP over what you would see with no cats. I'm running high-flows in my 996 RWHP DLM car, so they flow enough for a stock application
