How do I stiffen the GTS front frame?
Gene's98GTS
Chicago area
I suspect my left front wheel lock is related to torsional stress on the cars frame, and am trying to stiffen it. Anyone done it?
Chuck 98 RT/10
tampa, fl USA
If you are talking about lockup during hard braking then you need to get height adjustable shocks and scale it.
As for stiffing the frame there is a recall for the front steering rack.
cgmaster
Mississippi
I have looked at the front end on my car and thought about doing some work. Mainly a cross brace like on the GTS-r.
What you are experiencing is a corner weight imbalance because the driver and battery add more left-rear weight, unloading the opposite (right-front) corner.
The frame can be stiffened by welding a cover plate over the holes on the lower longitudinals near the back of the engine. ***HOWEVER*** This will negate the factory-designed crumple zone performance of the frame in the event of a frontal impact.
