How to change fog lights to yellow from white....
rgifford
Blacksburg, VA 24060
Anyone got any ideas?? I have always loved yellow fogs and the contrast that they bring. I guess some clear yellow plastic would work but there has got to be something better. Does anyine know what to the racing teams use??
Robert
Scorch
Shelby Township, MI
Hey Robert. The only way to convert your existing fog lamps to yellow is to add a yellow piece of plastic (use polycarbonate, acrylic may melt) between the inner fog lamp lens and the outer cover. No one makes yellow fog lamp bulbs (that I am aware of).
If you do find yellow bulbs that fit make sure the wattage is close to original equipment. Higher wattage bulbs will draw more current than your cars electrical system is designed to handle.
Your last option would be to find a set of aftermarket lamps that will fit in your fascia. Mounting them might be tricky.
Good luck.
Terry
