How to: Keep the inside of the your windshield clean?
Andrew/USPWR
W. Palm Beach
I don't smoke and rarely put the top down but, I always seem to have a film on the inside of my windshield which is not always easy to get off. Anybody use anything besides windex?
Andrew
Affatica
Denver, CO
I use the ArmorAll window cleaning wipes then go back over it with a microfiber cloth to make sure I get the streaks out. The wipes prevent any overspray on the interior.
Affatica
Denver, CO
Oh yeah, and the film is caused by the chemicals used in the plastics and leather in the interior of the vehicle as well as the cleaning agents used to clean the interior.
Solid Red 98
I have heard it referred to as vinyl smoke, which is caused by all of the chemicals off gassing from your interior plastics. Great for the lungs huh? I have had the best luck removing it by using alcohol for mild cases, and ascetone for tough cases( don't use if you have tinting of any kind). I never really had problems with much fogging until I started using protectants on the dash.
mike & juli
Upstate NY
Ditto...and yeah, using the defroster usually will add that film again. Yep, I said defroster!
LOL~~~juli
mike & juli
Upstate NY
Andrew/USPWR
Andrew/USPWR
W. Palm Beach
WOW! Thanks people. I was worried it was just me. I'll try those wipes.
What about the RainX anti-fog stuff? Anyone use it? Fogs not an issue in FL but I thought it may help the other problem as well.
29OUTLAW
Solomons Island, Md.
mike & juli
Upstate NY
I've also used Rain-X sheets too...they work VERY well on inside fogged windshield, side windows. ~juli
Hamrhead
eastern, Pa
Most of the time I just use a wet sponge and a towel. Seems to work quite well.
Every once in a while I'll use Windex.
Chris(NJ)
Central Jersey
yep! off gassing from the dash/interior. :crazy2:
I just use stoners on a mf glass towel to clean it, knowing I'll have to do it again soon :(
mach4444
Naples florida
I found out, by accident, that meguirs interior quick detailer works great on a cool windshield. better than glass cleaners as long as you are sure you remove it all.
agentf1
Phila Suburbs
Give Stoners Invisible glass a try.
For the outside I occasionally use Zaino Glass Polish and it will make the windows a little shinier and make the wipers work great. I have also had GREAT luck with Aquapel for repelling water and making wipers work smoothly. Not that this is much of an issue with most Vipers as I know the only time mine sees rain is if it is an accident and the weather guy screwed up. :dunno:
Andrew/USPWR
Andrew/USPWR
W. Palm Beach
Thanks:2tu:
ACR VYPR
NorCal (707)
Andrew
I have a dry eraser stashed in the glove box. It works great to get the fogginess off.
srcsrt10
The best window cleaner that I have ever used is distilled water mixed with a little bit of alcohol and vinegar ! It cuts thru everything and won't streak.
JKGiant
