how to raise car
whatthe
I put together four wooden blocks for the wheels to sit on so I can change the oil and do other maintenance things is there a special way to lift the car? should I lift both front wheels first then the back? or should I lift one side first then the other or does it matter? or should I just have a beer and prolong the fourth of July holiday
DrTaco
Oak Lawn, Illinois
Low profile jack on jacking point will lift up entire side or front (depending which point you use) of the car. Throw 2 jack stands in place and repeat on the other side. You'll be amazed how stiff the frame is.
speedracervr4
Lancaster, PA
In in a related story, I had to change my oil in a Walmart parking lot yesterday on my way home from Florida...Long story, but an injector stuck open and I was worried the fuel contaminated my oil. I did lower the car down after removing the plug to get more oil out. The Frame is really stiff, hence the reason why I love the Race Ramps.
Bugman Jeff
Wisconsin
Typical sports car owner, thinks he's gonna be cool and take up four whole parking spaces :lmao: :D
As for getting the car up, I built myself a set of ramps out of some 2x10's I had laying around. Starting with a 5' plank, they're stacked 5 high with each "layer" a foot shorter than the last. This gives me enough length that I've never had clearance issues with even the lowest cars. If I have to do major work, or need it higher than the ramps, I just use my low profile jack on the jacking points outlined in the service manual(if you have one), and put my jack stands under the frame.
eucharistos
Houston
that's a great pic :2tu:
speedracervr4
Lancaster, PA
It was the 4th, so I wasn't sure they would be open. Service manager at Walmart mentioned an hr wait and I still had some driving ahead of me.
Qdog
