How to remove clutch release bearing
Schulmann
Canada
I am changing my clutch and I got a new release bearing.
I have no idea how to remove the old release bearing from the slave cylinder.
Any help ?
Tom F&L GoR
Wappingers Falls
Push the plastic ring at the connector into the fitting to unlatch the internal hooks. It's a lot like the fuel line fittings, if you've ever changed a fuel filter.
Schulmann
Canada
Tom, you just explained me how to disconnect the slave cylinder fluid line. I am already beyond this point. I want to disassemble the bearing from the slave cylinder.
Schulmann
Canada
Thanks Ulysse !
It is really easy to remove it:Basically you turn (left or right doesn't matter)the plastic ring, then once it is blocked you turn it to pass that lock and that's it.
hemibeep
Tampa FL
Where is the best(cheapest $) place to get this? ?
Sounds like a good idea while replacing clutch.
