How to save $400 on steering problems
Tom F&L GoR
Wappingers Falls
I had a bad inner tie rod on my '94 steering rack and found that the inners aren't serviced. (They are on other types of vehicles.) The symptom (besides the loose clunk when the wheel is in the air) is even worse rut tracking than usual. The service fix is a new rack, which is roughly a $500 part, depending on where you go.
I recall reading that the Viper rack and pinion system was taken from a Dakota, so I ordered the inner tie rod from a '94 2WD Dakota, Moog EV 252. Lo and behold, the important inner end does fit, although the threaded end where the outer tie rod screws on is 1.5" too long. (Vipers and Dakotas do share the same outer tie rod.) However, it's easy enough to cut it shorter, thread the remaining end an additional 1.5" with a 15mm x 1.5 die, and presto-> Viper inner tie rod.
The replacement Dakota part is about $30; if you can't turn down the Dakota part and run new threads, I can't imagine a machine shop would charge more than $50 to do two of them. So for roughly $100, you can avoid a $500 steering rack replacement.
In truth, I bought both the Dakota part and as a back-up plan Bob Woodhouse sold me a used Viper piece. I put the Viper part on because of timing (tri-state AX event tomorrow) so I appreciate his help. But a few years from now, when the routine maintenance stuff hits and there aren't used parts to go around, you can go for the Dakota part.
Ron
Indianapolis
<FONT face="Comic Sans MS">Another valuable post for the binder.
Thanks Tom!</FONT f>
Vic
Maybe there is a way to find out where all the various parts were sourced from, and make a reference.
That way, in the future when we need a part, we can go to the original manufacturer.
Thanks for the terrific post.
Tim
Leduc Alta
Tom,
How many miles on your Viper?
Maybe what we need is a Forum dedicated to tracking these items that save money. Like the blood pressure bulb for $2.00 and not Dodge’s $70.00 for the lumbar support, or the air box clips from the GM Tahoe that I believe sold for under a dollar and not Dodge’s whole new intake take system that they sell for how many hundreds of dollars?
Just an idea.
Tim
99 R/T 10
Enterprise, AL USA
Hey Tom or anybody else that may know, Aren't the Gen I and Gen II suspension parts different? I thought so, but if they are the same, bonus!
Mike
T
Tom F&L GoR
Wappingers Falls
My '94 just turned 54,000 miles.
In other reading, the front suspension between Gen 1 and Gen 2 is essentially the same design, but made of aluminum. (Lower ball joint moved from knuckle to arm, but parts are same dimensions.) Rear suspension is different, though. Therefore, I suspect Gen 2 inner tie rods are also the same as Gen 1.
The '94 service manual says the rack is a TRW part. Therefore, I would say other TRW inner tie rods are also the same - the only difference is the length of the threaded end for the out tie rod. We need to find that master parts book that simply lists the lengths.
Tim, I would love to contribute to an "alternate parts" forum. I am going to drive mine as much as I can, AX, track time, and daily driver, so keeping it on the road in a frugal fashion is key.
