I broke my power steering pulley into pieces, does anyone make metal pulley
V
vegasviper
Guest
Also, does the PS unit need to come out of the car and have pulley pressed in or it just slips on?
hemibeep
Tampa FL
Make sure you have a puller....this might as well be welded! Not easy to pull off!
Joseph Dell
Atlanta, GA 30338
Re: I broke my power steering pulley into pieces, does anyone make metal pu
march performance makes a nice pulley. so a SEARCH and you'll fidn the part #. like $89 methinks.
JD
V
vegasviper
Guest
How about when i put it back on, do i need to have it pressed on?
hemibeep
Tampa FL
You can put it back on with a good grade 8 bolt/thick washer. The amazing part is how hard the P.S. pulley is to replace and the alternator pulley just falls off!
Ar Tee Ten
