IAC motor pintle always open?
FE 065
MI
Out of curiosity, I disconnected my IAC motor hose from the air box, then revved the engine a bit to see it the pintle inside the IAC motor closes completely once above idle speed.
It doesn't ! There was still just about the same amount of suction present at 2500rpm or higher as at idle.
While my service manual says the PCM adjusts the IAC based on various inputs, none of the listed inputs has anything to do with the car not moving or mph...
Doesn't the IAC close at all once underway? Anyone know more about that - more than the apparent obvious?
Maybe the Wizard knows..
Viper Wizard
South Salem, NY USA
That's great, Thanks!! :2tu:
To your question, no the IAC never closes all the way! The PCM & O2 sensors are adjusting for that vacumn leak. At an idle then the IAC starts to move to mantain you idle anywere from 550-750 RPM. Your idle is a controled vacumn leak.
Hope this helps?
F
FE 065
MI
Hope this helps?
Thanks Chuck :D
Jack B
NE Ohio
You need a scan tool to track/log the IAC.
RAYSIR
Salem, OR
Also the throttle position sensor sees the above idle and has no reason to close. Getting ready for the close of the throttle.
