Im trying to install a new front facia and the oem wont come off!!!
VENOM600HP
Does anyone know how to get this oem front facia off the car, i took the side bolts off and the 8 bolts under the facia and it wont come off i did a search and found nothing please for the love of.. .. someone help?
Patrick Mullins
1993 [******] Venom 550 VIN#0007
PBJ
St. Louis, Missouri USA
Venom600hp,
There are 5 push in clips on the top of the fascia under the hood opening...they are fun to remove. Make sure when you are removing the fascia to disconnect your fog lights and marker lights. Hope that helps.
Later,
Joe
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
There are also 4 push in plugs externally at the top of the air inlet to the radiator...two on each side of the vertical split of the crosshair. That should do it! :D
Bad_Byte
Corpus Christi Tx
There are also 4 push in plastic clips under the front lip. Not easily seen. Get a good flash light and look under front of the facia two are almost under the hood latched the other two are near the center.
Disclaimer: The above is the way my 94 has them it may be different on others I'm not fortunate enough to own one of each model. :D
Quantico, VA
I just did this the other day....send me your number and I'll call you and walk you through it. I know THAT works 'cause Tom Sessions did it for me!! :)
VENOM600HP
i broke all the plastic screws cause i was getting freakin frustrated :)
im trying to install the [******] [******] venom aero front bumper and it wont fit...i cant get both sides on evenly...
thank you for your offer vipermad, if you know how to get this darn venom bumper on we can talk :)
Patrick Mullins
1993 VENOM 550 VIN#0007
Quantico, VA
So you got the old one off???? I can help with that if you haven't.....I can't help with the new fascia other than to say it **should** go on the same as the old one came off, or thereabouts. :)
