PhoenixGTS
Would I need a whole two miles of runway/road to give the car a proper chance to show what it can do from a standing start to top speed?
For me 6th @ 6,000 rpm = right at 200 mph which, of course, my car would never do, but the sweet spot around 5,250 is in the high 170s range in 6th so the car will definitely go faster in 6th than 5th (and with an extra gear to help I am guessing it would get there sooner than with stock gearing).i see taht you also have more aggresive gearing in your trans too. in order to pull that 6th gear though i still think tht you are gonna need alot more power though. the stock 3.07 gear which i am currently running will take you to 202 mph in 5th gear at 6,000 rpm's, that is if you have enough power to pull it.
if indeed your modified trans gearing coupled with your 3.55 gear outback hits 200 mph in 6th gear at 6,000 rpm's then you might just be able to get close to 195 mph.
