Ipsco parts with GO Factor
Fatboy 18
Surrey, United Kingdom
Just got a pair of Anti Tow Brackets from Mark at Ipsco :2tu:
They come in plain Ali, so I added a bit of bling factor and got them Anodised Fast Red over here in the UK :D
Now That's Better :D
That's another 50 BHP on looks alone :D
CEJ
Raleigh, NC
They look great! I'll be curious to hear your take on the difference they make under braking.
ViperTony
I love these. I installed them on my Viper 2 years ago and I noticed the difference under hard braking. To me, my Viper feels more stable now when braking hard especially on the track. These definitely help in my case.
Detlef
Northern Colorado
I have them on my GTS as well and it does make a difference under very hard braking. Back end is less twitchy. Plain aluminum here, no bling.
ELW98
Bridgewater, MA USA
Will these work on a genII that has had the rear frame recall done.......someone told me years ago that they will not fit on ONE side because of the welded ad-on bracket?
thanks,
ViperTony
thanks,
I'm told these won't work with the recall. Best to check with Mark or call Tator.
F
Fatboy 18
Anyone have the code number for the recall? Tried to fit these today........ARRRRRRRRRRRRRRRGH They do not seem to fit :mad:
It seems the curved radius of the diff frame brackets is not allowing the face of the new brackets to lay flush, the curve of the frame bracket is cutting into my new anodising :mad:
As the face is not correctly fitting this is resulting in about a 1/4 of an inch gap at the other end of the bracket where to should tighten up to the anti roll link.
Will post pics so you can see what i'm talking about.
colo08
They should fit your car with no problem make sure the two brackets are on the correct side. they are marked with an "R" (Passenger Side) and an "L" (driver). Send me some pictures and I will look and see If some thing stands Out.
F
Fatboy 18
Right then, Pics...... you are looking at the anti tow bar and diff frame bracket from the Passenger rear wheel well, (right hand side)
Masked up the bracket to try and avoid scratches while I figured out how to mount them.
Anti tow bar, Note nut removed ready for new longer bolt
It helps to temporarily remove the hand brake cable screw ;)
Frame bracket is cutting into the new bracket :(
If you look closely you can see the gap between the Anti tow bar and the bracket!
This bracket radius seems to be part of the problem?
You can see where the bracket is cutting into the new Anti tow bracket here.
I did not want to tighten up the bracket any more causing more damage :(
F
Fatboy 18
Update:
Got underneath the car today and checked the status of the frame brackets and fitted the new brackets.
No1 My car is a 2000 car and has not had the rear frame recall work done (N/A on 2000 models).
I was trying to fit these brackets from the outside of the car via the wheel arches. The result of this is I could not see the opening gap as I released pressure on the main bolt and frame bracket of the rear diff housing arm, I was not expecting the frame bracket to open up so much, so when I offered up the brackets (in my earlier pics) there was a large gap between the back face of the bracket and the face of the Anti tow frame.
When you actually get under the car and release pressure on the bolts all becomes clear.
The good news is I did not have to grind or trim any of the frame brackets and upon tightening the bolts everything gets pulled into the correct position
Will post pics of Brackets in position later :)
