Is there a trick to hooking up the Remote Starter
V
vegasviper
Guest
for bumping over the engine. How do you make it work when the clutch has to be pushed in for the engine to turn over?
zen garage
Glenview Illinois
Why? You live in vegas. Remote start is for cars like my snowplow that sit outside in winter.
I have put remote starts on several stick cars, the installers always warned me about it, but they did it anyway. I believe there is a bypass but I have no clue. Pay a pro.
dblankenbaker
Scottsdale, AZ
No tricks... There's a HOT terminal on the side of the starter away from the engine, and another terminal on top of the starter. Connect the remote starter to these two terminals.
EDIT: Make sure your car is OUT of gear. I assume you're asking about bumping over the engine to adjust rockers.
V
vegasviper
Guest
That is correct.
I hooked the + to the starter terminal facing the engine with the plastic cover on it.
Will try your way
BarryLB
