issues with stereo
SuperSaiks
Hi Guys
My stock deck is starting to act up.. when I am playing a cd, and press the the track buttoms to skip to a new song etc lately its not playing the new track,
Tried a couple of different cds etc same outcome... so i just eject it and reinsert the cd and it works again, tried pressing the play buttom but it just says "pause"
Any thoughts
GTSnake
Motor City
Sounds like you have a defective unit. Just replace it or put in an aftermarket system. It's not worth putting any time into it.
SuperSaiks
Any suggestion on name brand aftermarket units, I heard from previous posts that the stock wiring harness does not attach to any head unit... is that true???
GTSnake
Motor City
Most aftermarket head units will need an install kit. It has a harness that connects to the stock connector and another one that connects to the new unit. When I installed mine it took about 15 mins to solder the wiring on each harness together then another 3 seconds to make the connections in the car. It was literally a snap.
BTW, if you replace your head unit you'll need to replace the amp at the same time or spend more time and money to convert the connection back to a DIN connector that the stock amp uses.
hemibeep
Tampa FL
For the 97' the alpine unit uses a Din to connect to the amp.
There is no plug-in adapter, it will require a little wiring. Also the antenna has a signal booster that is switched. I have added this to my amp turn on, to avoid a constant drain. I ran RCA to rear amp and left factory wiring intact, by pressing the pins out of factory harness(did not want to cut up factory harness)
