Wow you guys are crazy. I used to just use some newspaper to back up over so I could fit my jack under the car. Then I got more civilized and used a 4 X 4 about 2 feet long and sawed it with a taper from 1/4" to the top and left about 9" of flat. Now I just back up on this board on my driver side, so I can get the jack under my Eibach lowered car, and then jack it up on the loops, and use 4 jack stands that are rated 3-1/2 ton each, and I have the whole car up on jacks and level in 5 minutes. The car is so stiff, and the jacking points are in such a position, that when you jack up the driver side, and then let the car settle back on the jack stand, the passenger side pivots up in the air. The go over to that side and jack it up a little less than the driver side, and you are done with the front. Then to the back side loops just in front of the back tire on the driver side and jack it way up and put a jack stand under this side and the oil will drain out better, because you are actually leaning the car more toward the drain hole. Where in the heck are you going to store those big giant ramps that weigh 80 pounds each???
