I recently started experiencing the car bucking/kangarooing at low speed - nothing too dramatic although a quick clutch dump prevents anything too ugly happening.
It happens at low rpm when the engine is pretty much unloaded - you know those moments when you're cuising at 20mph down the high street, everything is sweet and ticking over nicely then you need the tinyist touch more/less throttle which results in the start of bucking/kangarooing, so you have to dip the clutch.
I'm sure I'm not the only person that's experienced this and I'm sure I read about this before but never paid much attention because I've never suffered with the problem.
Now I am suffering, not sure why or what I've done recently to bring it on.
Another symptom I noticed today (doing static emissions tests in the garage) when I tried holding the throttle with engine at 1500rpm, the engine oscillated between 1200 and 1500 rpm every 5 seconds (my foot was absolutely frozen solid, perfectly still) - eventually the engine settling at 1500rpm after say 60seconds or so. The engine was warm and up to operating temp.
Any ideas?
I'm thinking alignment of the two throttle bodies with each other could be contributing to this...
Any ideas?
Great stuff Ade, how the hell did you find the problem? Or did the Garage find it?
