Let's see some Gen 1 & 2 custom engines!
dave6666
Complete from the TB's back. Oh and without my world famous custom made mirror polished stainless steel Belanger header heat shields.
Kraaken
Palm Beach
Nothing crazy just clean dress ups here
Kraaken
Palm Beach
Ok sorry to barge on the post but how is everyone posting their pics... Photobucket codes or something?
speedracervr4
Lancaster, PA
Not the best pic.2.8L Kenne Bell,70MM Throttle Bodies, JMB intake, catch can breather set up, AB wires,Taylor separators, and with Iconel heat shields. I also replaced the ugly valve cover bolts with Allen head bolts.
J
Jance GTS
Oklahoma City, Oklahoma
Yes you can use photobucket codes or if already have the link to the picture just select the "image" icon and you can copy and paste your link and the picture will appear.
Awesome looking engines!!!
J
Jance GTS
Where is everyone getting their air filter setups at?
Don't you lose horsepower because you are sucking in hot air because it's not inside a complete enclosure? :dunno:
speedracervr4
Lancaster, PA
I got mine from JMB. The long version actually pulls air from a slot on the fascia. On the dyno it probably heat soaks faster, but no so much on the road.
Goatman
Houston, Texas
My RSI Unlimited with a Hot air intake. I will correct this. But its difficult to find a 2001 airbox. I will look at the JMB and see if I can get one there.
BlackSnake99
Northern Virginia
This. Mine is the JMB Powdercoat long version as well. Very high quality product. It is actually not open as the top of the box seals against the hood around the NACA duct when closed. Like srvr4 said the long version supposedly pulls air from in front of the radiator.
Vipuronr
Mine is pretty stock, some billet pieces, stainless steel cap screws and the like....no major mods or powder coating like some above.
Stahlhart
Hi,
still not finished...
Jürgen
VIPER BAZ UK
ENGLAND
A few of Bumble......
Forged pistons and rods,Cauldwell GTSR heads,mopar performance cam,10lb Roe supercharger,07 ABS SRT10 Brakes and wheels.Full borla exhaust,light weight alloy flywheel with upgraded clutch,Eaton TruTrac diff,Jon Danato Transmission and DC Performance re-map
Bo knows
Guilderland, N.Y.
Tried to do mine a little different.
Sybil TF
This thread should be re-named, Let's see some gen 1 or 2 engine pics with SC's or TT's. Show off's.
jpolen21
