SilverViperGTS
Here is the story:
My engine had compression problem in cylinder no.8. They removed the head and they had to replace two valves, two pushrods and they had the head resurfaced. They also replace the head gasket. I got my car yesterday and everything was fine until I got home (20 km away from the garage). I then pushed the car to 5000rpm (the engine was running fine and the temperature was perfect) and I saw white smoke coming from under the hood. I stopped the engine (the temperature was also ok at this time) and I saw a huge trail of prestone behind my car (at least 5 to 6 liters). I checked under my car and I saw a big pool of prestone (at least 2 liters). Bottom line, my car lost almost all its prestone in less than a minute!! It looks like the leak comes from the radiator!! Do you have any idea of what is going on? Keep in mind my car NEVER overheated.
Edit: When I started the engine the first time, I heard a little whistling noise... like a tiny supercharger noise.
