Map sensor Low voltage code
GTSnake
Motor City
Bad MAP sensor, loose mounting, oil contamination...
I had the same thing on my MAP sensor. The Roe system doesn't have a solid mounting location and is only zip tied on. Make sure the zip ties are tight.
V
vegasviper
Guest
Its zip tied and i changed the MAP sensor. How would oil come into play?
GTSnake
Motor City
If you have any blow by from the SC. Do you have a catch can?
Did you clear the code after you changed to a new sensor? Are the zip ties tight? Mine was loose and it threw a code.
V
vegasviper
Guest
I have blow by and a catch can. MAP ZIP TIED WELL
GTSnake
Motor City
Was the code cleared and it keeps coming back? Are there any obstructions in the vacuum tube? Electrical connections tight? Other than that I'm starting to run out of ideas.
Bill B
Plantation, Fl. 33323
I could be something else on the 5v circuit. I was showing a bad intake air temp sensor (low voltage) so I changed it. I was still getting the code for a intake air temp sensor and a bad tps (low voltage) so I took it to a friends shop so we could plug it in and that's when it showed a bad map sensor. Granted this was on a OBDI (95) and the OBDII is a more precise trouble shooter but you may want to check anything on the 5v circuit.
