Master lube install question? Where's the oil galley plug?
1KoolAsp 14TA
Long Island, New York
Master lube install question? Where\'s the oil galley plug?
I bought the master lube to pre-oil the engine before starting. I would like to know if any of you guys have this system and how you installed it. I also need to know where you hooked the oil line up. It needs to go to an oil galley plug. I looked by the oil filter and I don't see any plugs! I hope maybe you guys can help me out on this. I can't use the oil pressure sending unit because there is no room to fit a "T" fitting in there. The spot is to tight.
Jack B
NE Ohio
Re: Master lube install question? Where\'s the oil galley plug?
There is room for a Tee-fitting. Remove the NPT-to-AN adapter (15/16" wrench)that is on the rear side of the filter adapter (from oil cooler). You will have to temporarily remove the filter to get at the fitting. Then install a Tee that is a 1/2" npt into the adapter and two #10 AN males out.
I have a question for you, the Master Lube unit has to be kept vertical. Where are you going to put it and what size unit are you using.
1KoolAsp 14TA
hi jack to answer your question. i am removing my windshield washer tank. It will mount vertical there.iwent with 2 quart size .is that my only way to install line? there is no galley plug?
