messed up resetting pcm ? help needed
madbrian
i have just removed back wheel ,earthed out live side of cable to the battery earth and all was going well until i started the car and forgot to do the throttle sensor procedure .
what will the symptoms be by me forgetting to press the throttle pedal up and down ?
thanks
cayman
Missouri
I've done the same thing a time or two. I've never really noticed much difference either way (doing the TPS calibration versus not). It may just take a little longer to relearn. I've had issues with the idle oscillating at a stop but after a few driving cycles, it went away. And I've had that issue both from not calibrating the TPS and with calibrating it. Otherwise, nothin else much in my experience.
