My engine job begins
carl B
United Kingdom
inlet off first
C
carl B
United Kingdom
Roe Blower,Greg Good heads. T&D's Weldon pump, 70mm TB's, Ali Rad, Forged pistons, Early cam, Ballangers
PhoenixGTS
Phoenix Arizona
Don't forget a 180F thermostat and overdrive water pump while you have everything apart.
P.S. Man I wish my engine was that clean.
VIPER BAZ UK
ENGLAND
Hi Carl
Glad things have got off to a good start...
Keep the pics of progress coming..
Good luck
Baz :2tu: :2tu:
PhoenixGTS
Phoenix Arizona
Sorry I got the stat but tell me more about the water pump?
Carl
Both Tommy Archer racing and West Coast Vipers offer an overdriven water pump with upgraded impeller. I just installed the WCV unit but do not have any miles on it. $600 with core from WCV. $1k+ from TA but I think that is with entire pulley set.
Joel
Ireland
Sound descision, do you need the 97 cam though on a blown motor, your later milder cam might be better suited to the supercharger. Just a thought......no definite info to back it up. In 2001 there was a problem with waterpump impellors. Cant remember which year yours is ?
Joel
Ireland
Might be worth thinking about a new pump just as a precaution.....the impellors on a batch were prone to loosen if I remember correctly. Dan Cragin would have the full story on this, may be able to help you.
AlbertFattal
Los Angeles
Be sure to tape off your inlets and outlets when you are not using them. And clean them off before inserting them.
EA6BPilot
Alexandria, VA
Carl,
Are you going to have the cylinder walls honed? Also, how hard is it to remove and replace the pistons? The reason I ask is that I might have to replace my rings and was wondering if it can be done without removing the engine. Thanks!
Frank
C
carl B
United Kingdom
wrist pins require pressing off the rods
i will just glaze bust the bores prior to fitting the pistons
i need to file the ring gaps too as i got the file to fit rings
Carl
C
carl B
United Kingdom
Yes I have the ARP kit but I was a little concerned how small their washers are compared to the factory bolts
Carl
Neil - UK
ENGLAND
when you said you were gonna mod your viper, I didnt expect it to done within the week :2tu: hope all is going smoothly and to plan
Jim Wilson
Chandler, AZ, USA
Carl,
Great post! I plan on doing virtually the same thing this summer except I have a centrifugal type SC. Please post any "lessons learned" or tips on the whole project.
I was planning on removing the engine for easier access when doing the pistons/heads, etc. Is it fairly easy to do it with the engine in the car?
C
carl B
United Kingdom
So far as I can see it all comes out pretty good with the block still in place
Will tell you next week about how the cam removal works out
Carl
Joel
Ireland
Carl, what kind of oil pan kit is that, its totally different from mine..........where are the trapdoors and whats isolating the oil down in the pan, the baffle is very open.
C
carl B
United Kingdom
trap doors are beneath the butterfly baffle and it looks very similar to the one on the Archer site
Carl
Joel
Ireland
It looks like there is nothing to stop the oil sloshing up the inside of the crankcase when cornering
zeeshan_k24
