On your way to the start line stay out of the water if you have tires with tread.
It's hard to keep from driving through some of the mess they make with the water, so you will need to do some burnout.
You will probably find the starting line traction to be less than you are used to on the street. You may get lots of spin, watch for it.
Watch for it at the shift to second too. You can get in real trouble if the back end starts to slide after your shift to second.
If the car isn't pointing straight down the track, you should let off enough to get it back in control.
The shift out of first will probably come faster than you think. It's hard to watch what you are doing keep track of wheelspin and the tach at the same time.
Don't start out trying to get a super start or shifting real fast. Take it easy on the starts to begin with. Just make clean runs. Look at all the data on your slip and try to improve with each run.
When you are a rookie, your Viper can do more than you can get out of it.
It's an art.
