My GTS waaay down on power--why?
Joseph Houss
NJ USA
John,
Believe it or not, it could be the battery. When my '96 wasn't idling well (especially when slowing down for a traffic light, etc), it turned out to be not enough voltage to the idle sensor.
Just a thought.
Tom Friend
Kingston, WA USA
Check your fuel level and / or sensor. I remember reading somewhere in my service manual about the engine going into a "limp home" mode when it senses the gas tank is almost empty. It would shut down some of the injectors & other stuff as I recall...
SteveBCloud9
Roselle IL. usa
I'm with the battery theory too. Better yet, disconnect it for 2-3 minutes and reconnect it to reset the computer. See if that helps.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Hey John! Welcome back.
Low Voltage / bad battery. My firt vote
Fule Pump pressure fault a possible.
Bad plug wires / coil wires.
DONT discon the battery yet as it will erase the codes that the Tech needs to read to ID the problem !
Mark Swanson
St. Louis, MO
In St. Louis, try Barry Hawn at Zeiser Dodge in St. Peters, or the Viper Tech at Royal Gate Dodge on Manchester (in Ellisville?). Barry's great - he works Saturdays sometimes, too, so you might be able to reach him tomorrow. I've heard the guy at Royal Gate is good, too.
jamie furman
woodbridge va
I agree its the battery my cars went dead the other day same simptoms until I charged it overnight and ran it didn't go away until the battery had enough of a charge to idle properly.
