Need help with a electric vacuum pump!!!!!!!
VIPER D
dutchess county, ny
I am working on a project and need a electric vacume pump to *** my pcv system. I was told that I can use a 1994-96 CORVETTE 5.7 LITER SECONDARY AIR INJECTION PUMP but it looks a bit cheesy
http://cgi.ebay.com/ebaymotors/1994-96-CORVETTE-5-7-LITER-SECONDARY-AIR-INJECTION-PUMP_W0QQitemZ8061026281QQcategoryZ33610QQrdZ1QQcmdZViewItem
I am sure that a hi performance company must make one. All the ones I have seen are either belt driven or brake booster vacume pumps
some please help!!!
thanks in advance
vd..
kmg99
Portland,OR
Viper D-
The Ford Super Duty Diesel uses an electric vacuum pump for the automatic 4x4 hubs that is OE quality, designed to mount under the hood, looking very much like it came from the factory.
The pump is manufactured by Hella for Ford. I am sure a Ford Dealer could track you one down quick. PM me if you need a part number and I will try to track it down.
Asp Man
Kelowna B.C., WEStern Canada
Check Summit or Jeg's or even Schnitz Racing for one. Popular drag racing equip., there are lots of choices out there from big pro-stock car to ones used on pro-stock bikes (Schnitz).
Good luck with your project.
viperkraz
You could also try Kaye Racing Products at kayeracingproducts.com They advertise in National Dragster magizine. I wired mine to start working when the gas is to the floor.
VIPER D
dutchess county, ny
Thanks for all the help!!!! I installed the pump and 5 hours later it burned out so I ran a the pcv line to the air filter right b/f the turbo. That seems to work so i will do the other turbo as well/
Thanks Doug (DLM) for the email
:2tu:
vd..
