Hey Guys, I have a problem that I really need help with. I have been fighting a few issues with the car and now I am so pissy that I don't know what to do anymore. I just need help. Here are the issues:
The first one is that recently I changed out my O2 sensors to try and fix the bog I get when the car is cold. I went and purchased BOSCH O2 sensors for the car and when I went to put them in, I noticed that the original O2 sensor wires were extended because of the relocation of them due to the SVS headers I have on the car. Ok, well off to the store to get wire. I extended the wire with 18 gauge threaded wire and put them in the car. I took the car out and now when it gets really hot, the car idles occasionally at 1800 RPMs. Obviously heat is getting in to the wire so I went back and took the original wire off of the old O2 sensors and soldered them on, replacing the wire I purchased. I assumed that since the old O2 sensor wire SVS used was good because I never had this issue before so I just used that. I then wrapped the wire with 2000 degree heat shielding just to further make sure I don't have any heat issues. Well, tested the car again and they were perfect for about 45 minutes of driving but then when the car got extremely hot again, the super high idle came back with a vengence. What do I do here? Do I call up SVS and try to get them to send me new O2 sensors that are already wired by them (hopefully they would do this for me.) Did I screw the O2 sensors up with the first wire I put in? WTH??
The second issue is a heat issue. About a year ago I blew my original radiator. Well, I purchased a PWR radiator and then called up JonB and got a new '99+ fan shroud. I put both of them in and ran for a while. I have a new radiator, a triple pass one at that, and my car is running hotter than before. After a short period of time, I blew that radiator (pin holes in the welding) and this time purchased a Ron Davis radiator from JonB. Put that one in and it is still running hotter. I took the car to a radiator place here in town and they flushed the coolant and put some new stuff in. They ran tests and said that the car was fine. Well, it wasn't super hot outside so it seemed fine. Now that it is hot outside, the car was running at the far notch to the right (notch before the redline) and my car now does that crazy idle thing that I mentioned before. That hot with a Ron Davis radiation - overflow tank has the correct amount of coolant/water/water wetter and it still runs that hot? Of course when it is that hot, the AC doesn't work and I look like I just ran a 10k run when I get out of the car. I swear that I could smell burning flesh in the car
Any advice would help and if someone wanted to come and help me out, I would be the happiest person in the planet. I would take it to a Viper Tech if WE HAD ONE here in Bend. I think the closest place is Portland and I don't want to drive it there like this.
I will note that when the car isn't super hot, it runs very good. Good power, no stuttering and it feels like I have every bit of power that I should have minus the altitude here in Bend. The car only has 17k miles on it now and didn't have a single issue with the car until I put in the new radiatior. I have tried to burp the thing like 1000 times. I shave my head but seriously, if I had any hair I would have pulled it out by now.
Thanks in advance.
- Ron (cornfish)
Thanks in advance.
- Ron (cornfish)
