New Take-Off Parts Available....
Sean Roe
Jacksonville, FL
The follow parts are original equipment from a brand new 2002 FE GTS with 18 miles and were just removed this week (the Viper was new, not damaged):
- 1 complete tubular exhaust manifold set with V-band clamps, flex pipes, 90-degree bends and catalytic converters (everything leading to the cat-back, fits ’94-‘02).
- 1 complete cat-back (’96-02)
- 2 front rotors (’92-02).
- 2 rear rotors (’92-’02).
- 1 set of front pads (’92-’02).
- 1 set of rear pads (’01-’02 only)
- 1 flywheel (’92-’02)
- 1 set of spark plugs and wires (wires fit Gen2 motors only).
- 1 set of intake / exhaust valves / springs / retainers / rockers. (Gen2)
- 1 set of pistons & rods (’92-’02).
- 1 camshaft (good for a core to be re-ground).
- 1 set intake tubes and filters.
- 1 set of halfshafts.
- 1 shifter (not the handle, but the shifter itself).
All items are available now and will be listed on the VCA classifieds and Ebay soon.
If interested in any of these parts, feel free to make an offer before they are listed.
Regards,
Sean
[email protected]
PS. More to come...
Sean Roe
Jacksonville, FL
Here's some more....
Recent take-off and new Viper parts available with quantity and condition (new or used). All used items are in good / clean condition (most from a 2002), most new items are still in their boxes.
- 1 K&N Filter set, used.
- 1 S&B filter set, new, had foam pre-filters removed (glue still present but will not hinder flow).
- 1 single S&B air filter, with foam pre-filter, new.
- 1 used VEC1 kit with air /fuel ratio meter.
- 1 interior door trim bezel, passengers side (goes around interior release handle), new, ’92-’98.
- 1 set of 20 Crower roller lifters, new, part # 66326.
- 1 Mopar Street Performance head (with bronze guides and CNC’d chambers), new.
- 1 Gen 1 intake manifold (bare), 3 rib from ’94-’96, used.
- 9 Gen 1 fuel injectors (black), used.
- 1 Gen 1 IAC, used.
- 1 Shift light by HighTechSpeed.com, new in box.
- 1 1998 PCM, new.
- 1 2002 PCM, new.
- 1 factory 2002 flywheel, used.
- 1 ACR oil filter adapter, used.
- 1 Gen 2 engine timing cover with oil filter adapter, used.
- 1 stock 2002 camshaft, used, (good for a regrind core).
- 2 stock 2002 halfshafts, used.
- 1 Differential rebuild set with output shafts, bearings, seals, etc, new.
- 1 water temperature sensor (’96-’02), new.
- 1 set of black Mopar smooth tubes with clamps, used.
- 1 coil pack, ’98-’02, new, right side.
- 1 Stoptech stainless steel braided brake like kit, front and rear, new in bags, ’96-’00.
- 1 stock spark plug wire set, 2002, used.
- 1 set of Magnecore spark plug wires, red, used.
- 1 stock 2002 timing chain set, used.
- 10 stock connecting rods with 9 pistons installed from 2002, used.
- 1 water pump, used, from 2002 (’96-’02).
- 2 water pumps, new (’96-’02).
- 2 front wheel bearing hubs, new, ’96-’00.
- 2 rear wheel bearing hubs, new, ’96-00.
- 1 differential rear cover, without bushings, used.
- 3 complete matched main bearing sets, black, silver and magenta, new in boxes, ’96-’02.
- 2 front oxygen sensors, new, ’99-’02.
- 2 rear oxygen sensors, new, ’99-’02.
- 1 stock radiator from 2002, used, ’94-’02.
- 1 ****** header set, used.
Regards,
Sean
[email protected]
Sean Roe
Jacksonville, FL
Items sold so far include:
- Both new water pumps.
- ****** headers
- VEC1 system
- K&N filters
- Mopar Smooth tubes
- "FE" Stock tubes and filters
- "FE" Stock plugs and wires
Items pending include:
- Rotors
- Pads
- Halfshafts
- Oxygen sensors
Once we get our other computer back, the rest of the items will go on Ebay.
Regards,
Sean
