Nitrous question
ohiodoc
Las vegas, NV
What is the best and safest Nitrous system to put on a stock 95. Something to give me maybe 100-150 extra horsepower?
RedEnuf93
Lancaster, PA
NX Express, it was designed and tested on a Viper.
If you look into my pictures, you'll see the system.
I have a -93 and check the signature for possiblity of adding 100HP... :D
J DAWG
MS
I went with the TNT kit. The F1 is rated up to 150rwhp. Unlike the NX it utilizes throttle plates that fit behind the throttle bodies and the nozzle is position in the plate.
The NZ has the nozzles screwed into the smooth tubes. I dunno if one is better than the other. I know the vast majority use NX and have had great results. I have also been pleased with the TNT and it is a real clean install.
People have said using the plate like TNT does maybe to close to the intake runners and doesn't give enough room or time for an even distribution, but again my plugs have been uniform and the car made good power and ran pretty good at th track.
John
J DAWG
MS
here's a pic of the nozzle and plate
Shelby3
liu;g
Stay away from Ny-Trex. I had two solenoid failures in the first week after installation. :usa:
J DAWG
MS
PBJ aka Joe Donovan from St Louis also sells the NX kit.
314-401-9946. This guy knows how to make power.
and I bought my TNT system from NitroDaves.
BigCarrot
Dallas, TX
I have said this before bigcarrot and I will say it again.............That is one badazz setup!!!! :D :D
And I've said this before, but I'll gladly say it again.... thanks!!
O
ohiodoc
Las vegas, NV
So with a 150 hp setup, my motor wont be in jepardy? I want to make sure nothing can happen to it. My motor is all stock right now.
Jack B
NE Ohio
A minor hint, nitrous power is very peaky without headers and exhaust. This how it all starts.
BigCarrot
Dallas, TX
Anything CAN happen, but you should be fine with a 150 shot. That's pretty conservative.
O
ohiodoc
Las vegas, NV
so what times should a stock 95 with nitrous run in a quarter mile? How much time should I pick up.
RedEnuf93
Lancaster, PA
Mid/high 11's should not be a problem with 150 shot and michelins. My car has a stock motor, only external improvements are smooth tubes/filters with 2002 "headers" (stock cast iron replaced with steel ones) and 3" open exhaust.
J DAWG
MS
I know some Gen2's with only exhaust mods running high 10's on a 100 shot with slicks and skinnies, so on pilots and a 150 shot your car "should" run mid 11's with a decent launch.
John
Andrew2KRT10
New York, where else?
I have an NX system 150 shot with mine going into the tubes, no direct injection, although looks like a nice setup. I am guessing the intake manifold has to be drilled and tapped for the nozzles?
Never tried a 1/4 mile run with the nitrous. I've only used it on the long course at Poconco. Lots of fun.
I was going to hook up my two bottles in succession this winter, but decided not to. Switching the bottles will force me to take the empty out and get it filled. I would like an electroinc guage though for inside the car.
AC
GARY J
I have 2 viper nitrous express kits for sale. THey have had about 5-7 bottles through them. I'll take any reasonable offer for them. There is also a bottle heater kit. Thanks.
