No more clutch problem...
jp
Umea, Sweden.
Will this solve the clutch problem...?
A McLeod fully adjustable SoftLok clutch, the stock T56 has also been replaced with a Jerico Clutchless 4spd transmission.
VinR1
Central Texas
you installed a bad-ass clutch with a clutchless tranny...? Im new to this - how does that work??
Daniel Cragin/DC Performance Inc
Los Angeles, Ca
Make sure you get those pressure plate finghers adjusted correctly or that new clutch may go up in smoke, they should be right at 0 preload. Once set right, that clutch will take the power.
J
jp
Umea, Sweden.
Daniel, we will do our best to find a working combination.
A clutch is about 3500, a tob, if you dont use the stock one is about 600. A trans is about 4200 etc etc. Then you need adapters and stuff.
Redthirst
