Noticeable clunk when tapping gas pedal during decel.
Jc121285
Lovettsville VA
So ive noticed this noticeable clunk under car when "tapping" or "goosing" the throttle more so while "engine braking". Feels like too much backlash in rear diff, or possibly trans mount failing? Of course this is a premature post as I have not yet taken the time to put the car on my lift and look around
yet. But curious if there is any known issues that you guys have come across as to steer me in the right direction when I do get a chance to look into it.
2000 RT/10 15,000 miles on her roughly.
Thanks in advance
AviP
New Canaan, CT
There is play in the driveline and that is what you might be experiencing. If it seems unusually long or loud, you might have a problem.
Jc121285
Jc121285
Lovettsville VA
Not unusually loud and no other accompanying sounds. Any idea where in the drive line the play is? The rear diff?
TalonTSi90
Any sprung clutch is designed to have play in it, hence the springs.
ViperJohn
Maryland
I think you are hearing the U-joint where driveshaft meets the rear end. You probably want to have looked at as depending on the mileage you may have excessive play in one of the U-joints. There will be some clunking from time to time due to short wheelbase though. How many miles are on your car?
TalonTSi90
He said 15k roughly lol.
