Apon delivery of my nice new STC Flash tool from ROE, I set about finding my OBD II plug to connect the reader to.
Now before you all start jumping in and saying it is near the drivers feet under the consel.... My car is converted to right hand drive(the proper side he he
). And after a good hour with most of the dash apart,upside down with all the blood rushing to my head,(I looked on both PAX and DRVS sides) I failed to find the plug.!!
I am guessing the company that did the conversion removed it.
1/Now Has any one ever wired in a new OBD II plug?
2/ I am guessing that all the pins originate from the PCM?
3/what pinouts from the PCM correspond to the pin ins to the plug.
I am looking at buying a plug from the local dealer and wiring it into the PCM direct and having the plug in the engine bay, this over comes two problems a) re looming though the fire wall b) saves me digging around the dash every time I want to check the tune/fault codes.
Am in New Zealand so will be doing this all myself as the dealers here have hardly seen a viper let alone worked on it.
thanks heaps if anyone can help
Craig
Craig
